Repairs Checking Charging System on 727K model
MVOTH
I have a 727K Grasshopper that I suspect either has a bad Stator or Voltage Regulator. However the regulator is mounted on the bottom half of the Kohler engine and not even visible except from the bottom through small openings in the frame. Does anyone know the best way to disconnect the harness from the regulator in order to test the stator output? Assuming the regulator is found to be bad, what is the best way to get to it to change it? Thanks.
