charging system not working on 12.5 briggs engine. I can not find voltage reg. Is it
zig317
  • / charging system not working on 12.5 briggs engine. I can not find voltage reg. Is it
charging system not working on 12.5 briggs engine. I can not find voltage reg. Is it in the ignition switch?
NorthBama
If it has a red connector down by the starter it doesnt have a voltage regulator just a diode to change ac to dc
Romore
Can you give us the model and type numbers stamped into the valve cover?
