started the unit, run the voltage check, 13 volt with and without PTO running, meeter says charging system weak,,,,,,, hold down the button to put draw in the system and it reads weak?? turn unit off and the voltage stays at 13volts, hit the key again and it turns slow and clicks, hook the charger / booster to it, run the charger for a few minutes, still turns slow and then clicks from low voltage to starter, switch over to boost, wait two minutes, hit the key and off we go,,,,,, run the unit for over 2 hours, turn it off and the whole thing starts over again, had to go retrieve the booster.:frown:
