Handle mounts in hand. The left side is straightforward. The right side has a nylon lock nut inside the carburetor compartment.
It is pretty tight in there. Can this mount be changed without removing the carb? I don't have a carb gasket on hand and don't want to make things worse if avoidable.
Has anyone done this repair?
