Engine Changing Engine Oil/Hydraulic Oil and filters on Radius w/exmark engine
JDecker
I've changed the engine oil after the 5 hr break in period and now its time to do a hydraulic fluid/filter and another oil change - on the Radius 52" mower with the Exmark engine. Are there good alternatives to buying the Exmark Oil and Filters? What would you recommend?
I owned a Bobcat zt 219 for 17 years and have replaced it with the Exmark
While it is under warranty I would follow what the manual says. After that use a good quality oil for both.
