I believe you are referring to the plastic pulsa prime carb that sits on top of the fuel tank. If so, here's how it comes off.
Remove the two bolts holding it to the engine block. The long rear one is a 1/2" and the short one on the front of the engine is 3/8". The carb and fuel tank can now be slid off the breather tube. There should be a plastic ring and a rubber O ring that should stay inside the back of the carb. Disconnect the linkage from the carb by tilting the carb down till the linkage Z bend comes out of the hole. The carb and fuel tank should now be separated from the engine. Remove 5 screws and the carb can be lifted from the tank. That's about it!
