Troy-Bilt Pony 2012 (Model 13WN77KS011)
This mower was struggling to climb uphill, and even threw the upper transmission belt. Upon inspection, all the belts needed to be replaced. I changed the deck belt, & both upper and lower drive belts with the Lowe's equivalent Sunbelt replacements, careful to get the proper belts. Put it back together, it drives great! No issues at all with belt slipping and the mower climbs a hill like a champ.
However, a new problem immediately appeared: the mower does not want to switch gears (Forward/Neutral/Reverse) while running. I can start it, get it into gear, and it moves great - like a new mower. The problem is when I then need to change gears, the shifter is super stiff and fights me and pretty much won't move into Forward, neutral, or reverse. I would have to seriously force it for the shifter to move, so I have avoided doing that. I can move the shifter smoothly and normally when the motor is off. The shifter adjustment bolt is in the same position as before my maintenance & the little shifter spring is in its normal spot.
What could be my issue here? Surely it has to be something to do with my recent maintenance.
Thanks for the help!
