The Kohler Command 26 hp engine on my Cub Cadet LT 1050 threw a rod. I have a Briggs and Stratton 20 hp Intek that I'm trying to use to replace the Kohler. I have the engine bolted on but I ran into a couple of issues with the wiring:
1. Both engines have a white 6 pin plug for the wiring. The B&S engine only has four wires, what are they for and how do I connect them to the Cub wiring which has 6 wires?
2. Also the cable that connects to the starter has a smaller red wire bundled in with the thicker "battery" cable and when I touch it to the B&S starter it turns over even with the switch off. What can I do to stop this and get it to work with the switch?
Or should I just splice in a starter button and hot wire switch? If I do that will it charge and will other things not work?
Please help!
Thanks!
Please help!
Thanks!
