07drummerboy
- Feb 5, 2011
- 6
- 21
I have a 6HP intek ohv engine on my champion ride on mower!
it turns over but thats all it does, i added fuel to the top of the carb (under the air filter) and it fired and ran for a few secs, the mower will not fire or run off the fuel going into the carb via fuel pipe so i took the fuel line of drained the tank put thresh petrol in it and checked the fuel feed. all this was good it still will not start so i took the carbuerettor off and sprayed through it with carb cleaner but this has not helped!
Any one got any ideas on what should be doe to get it right???? ????
Thanks For reading Joe
