TroyJackson
- May 9, 2014
- 7
I couldn't find a more appropriate forum for this question, I have a Husqvarna 575XP Chain Saw that will start, but stalls when the throttle is pressed. I removed and cleaned the carburetor and still have the same problem. It will start but will stall when the throttle is pressed. I also checked the compression release valve and it is no leaking. It will only run while choked and I can keep it running by working the choke. The high and low carb settings have stops on them and it doesn't matter where they are positioned.
I have changed the plug, air filter, fuel filter and plug. I have tried running it without the fuel filter, without the air filter, full choke, half choke, and every high/low carb setting that is possible and all combinations. I have pulled it until I have had chest pains with no luck. It has spark and I have tried it with starting fluid. Nothing that I have tried makes any difference. I t runs then it stalls...
Any suggestions???
Any suggestions???
