O ole20 Member Aug 18, 2018 #1 Dose anyone know P/N for these oil cooler hoses? Can I use oil hose from any auto parts store? M # CH22QS, SPEC # 66534 Serial # 2607121907 IMG_0128.jpg IMG_0125.jpg IMG_0126.jpg Attachments IMG_0128.jpg 76.5 KB · Views: 6 IMG_0125.jpg 79.5 KB · Views: 8 IMG_0126.jpg 120 KB · Views: 6
mhavanti Well-Known Member Aug 18, 2018 #2 Just pop them off, take them into the parts store. Have them match up the inside diameter with some decent nylon re-enforced hose and you'll be all set. Max
O ole20 Member Aug 18, 2018 #3 Thank you Max, I did not want to pull it apart until I knew where I could get the parts, I have done that to many times.
