Center spindle won't spin when blade is installed.
LarryJohnson
Almost ready to put the Murray into action, but having an issue with the center spindle on the cutting deck. The spindle/pull turns by hand without blade attached, but will not when blade is installed. The outer two spindles are fine with the new blades installed. I was able to get grease into all three. Is there some way to make an adjustment to allow it to spin with the new blade. Mower info is listed in my profile. Here's a pic.
Untitled
