CC30 Rear Engine Rider Stall in warm weather?
poppadaddio
My 2014 Cub Cadet CC30 Rear Engine Riding mower stalls, apparently when it gets too hot - when I try to mow when it is hotter than about 65 degrees. I let it sit for 20 to 40 minutes and it will start again, and run for a while.
On the advice of Cub Cadet phone help, I replaced the spark coil assembly, but that did no good.
Any suggestions? Thanks.
mechanic mark
Remove blower housing topside of engine & clean engine cooling fins with paint brush, etc. & shop vac, no water corrosion will set in. Check air filter for replacement. Let us know how it goes, thanks, Mark
