CC LT1045 HUB CAPS
DSHAFFER
HOW DO YOU GET THE HUB CAPS OFF OF ABOVE, SO I CAN CHECK GREASE IN BEARINGS? I THINK MY UNIT HAS SLEEVE BEARINGS, NOT ROLLER BEARINGS
Flintmotorsports
most of the time you just stick a screw driver flat head behind it and it pops off or there might be a little hole in the hub cap to stick the screw driver into and your model offers both high speed beargings and bushings
