spottedomelette
- Aug 7, 2014
- 1
- 1
Hi all, I am new to the forum. I purchased a CC AGS 2130 in the fall mainly to bag leaves. Recently I have been having issues starting the machine. I believe it is the oil pressure switch as it seems to start after I add oil, even though the dipstick reads "F". Is this an issue anyone else has seen? I searched the forum and found no discussion on it.
When I turn the key I hear a click and every once in a while if I click it a few times it will start which is why I was wondering if it was possibly the starter or solenoid.
If I jumped a wire between the two terminals on the solenoid would I be able to determine if the solenoid is the problem?
Thanks
Thanks
