Walk behind cc 760 es no start won't turn over
gcn
DAZZED AND :confused2: :confused2::confused2:GOOD BATTERY CLEANED CONECTIONS NEW ING SWICTH NUMBER 2ND. ONE , POWER AT SWICTH OK. / NEW PLUG/ NO T HR METER /, MOVER WILL NOT MOVE IN NEUTRAL POSITION UNLESS I DISINGAGE WITH CLUCTH LEVER ON LEFT HANDEL. CHECKING MOTOR GROUND NOW BUT DON'T THINK IT'S THE PROBLEM . THINK THE TRANS IS SHOWING TO BE IN NEUTRAL BUT IS NOT , DON'T KNOW HOW FIX MUST BE STUCK INSIDE ?:confused2: NEWBEE: THANKS...:rolleyes:
Colind67
I have the same problem with mine. Did you get it fixed? What do I need to do? Any help would be greatly appreciated.
