Castlegarden or Champion EL63 Juddering
JBASport
Hi, I have a Champion Model EL63 (I believe Castlegarden is similar).
Recently when in drive it has starting to judder (like slipping gears on a bicycle).
I am not sure if a worn drive belt would cause that (as I am not sure how to adjust the tension) or is it possibly the actual gearbox is at fault and would that be worth trying to fix?
Any help would be much appreciated. Thanks, Terry
