Carburetor needed
Ron9to21
Would anyone know where I could purchase/find a Mikuni 15003 2131 Carburetor for a 540V Kawasaki engine. The one on my 257H Wheelhorse is damaged and needs replacement.
BlazNT
I looked everywhere with no luck.
577jersey
Wow,,Google didnt even find anything on that,,looks like you are going to have to keep searching or try the dealer.
Might have to find a junker on CL or maybe even just get a replacement engine for it if worse comes to worse.
Whats wrong with the carb,how bad is it damaged??,,usually you can fix any carb by just cleaning out the jet ports real good with a steel guitar string and some compressed air.
Always helps to soak it for a few days in some kero or diesel.
Good luck bro!
Tom
treechipper48
Is there a dealer with Kawasaki parts in your area? If so check them.
577jersey
I have a couple spare FC420V kawi carbs,,not sure if they would fit but if you find they will I will gladly part with one for pretty cheap.
They do not have the fuel bowl solenoid so you would not have to worry about hooking the wires up.I have bypassed those things in the past with good results...just plug them up depending on the design.
