Folks:
I acquired a not running Craftsman Edger (model 536.797512, code 217006877) with a 2.5 HP Tecumseh Engine (143-824022, serial 2168B) at a local garage sale. I suspect it hadn't been used in years. I got it to start but it won't stay running. I believe the carburetor is all gummed up. And there doesn't seem to be a choke on it. Needless to say, I am not familiar with these carburetors. I took the attached picture with the gas tank and air filter removed. There is a short black hose coming out of the carb that has a plug in it. That doesn't make sense to me. Can anyone explain what the purpose of the hose is and why is it plugged. I have looked at pictures of identical carbs but there is no hose on it. What is the function of that red tube coming out of the carb? When I press the primer bulb repeatedly, eventually gas comes out of that tube. Is it just an overflow provision. I am thinking that the previous owner must have modified something along the way. I am wondering if that is not the correct carb for the motor. Can anyone set me straight on all of this?
All responses are appreciated. Thanks.
Bob
Bob
