quick-king
TB BRONCO - gas leaking Through fuel shutoff solenoid (?) Below the carburetor bowl. Where can I purchase a solenoid replacement? Replacement only way to stop the leak?
I am assuming you mean the fuel shut off solenoid. It's purpose is to close the main jet when you shut your unit down to eliminate backfiring after shut down though the carb. Check to make sure that the gasket between the solenoid and carb bowl is in good shape and the gasket between the carb bowl and carb body also. Should not have to replace the solenoid unless it is bad.
