Repairs Carburetor draining the fuel tank.
handload223
I have a Craftsman Eager-1 that is about 15 years old, it has a Tecumseh 6.5 hp engine. it started acting up, running in surges and has progressed to starting, running for a few minutes and then drowning itself out and draining the fuel into the air cleaner. I order the carburetor rebuild kit from craftsman and installed, with help from youtube, put gas in the tank and it drained straight out the tube coming from the carburetor. Any ideas?
Did you install the seat in correctly? The rings on the seat should face the carb body. Here is the procedure I use to rebuild a carb.
Needle and seat replacement
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. *Next check to make sure that the float does not have any liquid in it. *If it does, replace. *If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: *On the side of some Tecumseh carbs you will find a plastic cover. *Under this cover will be an idle jet. *Remove it and check to see that the jet is open both horizontally and vertically. *You should be able to push the old float needle wire through the vertical opening.
handload223
I performed all those steps also replaced the O-rings on the emulation tube.
redmondjp
You may want to also add an inline fuel shutoff valve - they are under $10 and easy to install. I put one on every motor where the fuel tank is higher than the carburetor.
I'm thinking you may still have an issue with the seat not sealing properly from what you are describing. Or a sunk or hanging float.
