Rick Witherell
- Sep 22, 2014
- 1
- 1
17hp Simplicity liquid cooled loses power after running for an hour. If I pull out the choke it will keep running. Also when the grass is thicker it will bog down and start to miss. I put cleaner in and it help a little. I also pulled the float bow and there was no dirt what so ever. Checked fuel line for cracks along with pulling line in fuel tank. I also looked at the fuel pump and it works fine.
