carbon spark plug
ACF
have a kohler ch25 that runs but have noticed that power drops off, after running for a little bit compression is 125 and 115 one plug looks good but the other has the black soot on it could i have a bad coil on that side
thanks
Auto Doc's
Remove the top engine cover, then unplug the single wire on each coil. That is a coil kill wire that has a diode for each coil made into it. Typically, one diode will fail with age and vibration and the opposite coil will stop firing.
A good test for checking if both cylinders are working and producing power is to use a spray bottle and spray water on each exhaust pipe. The water should burn off of each pipe quickly if each side is working correctly.
If one side is still not working, you likely need a coil.
I recommend Greentree.com or Jack's small engine for any parts you need. Avoid Amazon, too much junk and defect parts there. You will need the engine label model numbers.
Could be coil and or plug. Could be a counterfeit plug in that hole. See if you have over say 5k Ohms on the fouled plug.
