CARB PROBLEMS ! NEED HELP!!!! PLS !!
SR1642
JUST GOT A SNAPPER REAR RIDER 42 INCH CUT MOWER WITH 16HP BRIGGS VANGAURD TWIN CYL ENGINE. GUY SAID MOTOR WAS BAD. I TURNED MOTOR OVER AND IT SOUNDED GOOD. HAD BEEN SITTING IN WEATHER FOR PAST 4 YEARS. WOULD NOT FIRE SO I CLEANED FLYWHEEL AND BOTH COILS, STILL WOULD NOT FIRE SO I UNHOOKED BOTH GROUND WIRES TO BOTH COILS AND IT FIRED. SPRAYED GAS IN CARB AND IT RAN LIKE A SEWING MACHINE, QUIET, SMOOTH, NO SMOKE. GAS NOT GETTING TO CARB SO I PULLED IT AND AS EXPECTED IT WAS FULL OF RUST AND DEPOSITS. AFTER A SERIOUS CLEANING IT FIRED UP AND RAN AWESOME FOR ABOUT 4 MIN THEN STALLED. FIRED BACK UP BUT LOST MOST POWER WHEN BLADES WERE ENGAGED. CARB IS A MESS SO I WANTED TO ORDER A NEW ONE BUT HAVE FOUND OUT THAT THE 303777 FOR THIS ENGINE HAS BEEN DISCONTINUED. ALL I NEED IS A GOOD WORKING CARB TO HAVE A JAM UP SMOOTH RUNNING SNAPPER THAT WAS BELIEVED TO BE JUNK. ANY ADVISE? THIS MOTOR IS SWEET ONLY NEEDS A CARB. HELP... LOL...
mechanic mark
Genuine Briggs Stratton 807962 Carburetor Overhaul Kit Replaces 807708 808325 | eBay My son & I had same problem with ours, needed carburetor 808728, searched everywhere for a month, no go, ended up ordering B&S carburetor kit 807962 for engine 303777 1118-A1, code 95012611, disassembled carburetor & ran a piece of wire from loaf of bread or garbage bag through all ports, strip paper off wire, cleaned with carb. cleaner, installed new kit & carburetor on engine runs great after final adjustments.
Amazon.com: Briggs & Stratton # 807962 KIT-CARB OVERHAUL: Industrial & Scientific
Results
