Ropersscag
- Mar 4, 2013
- 1
- 2
I have a 23 horsepower kawasaki and I am having carb problems. I went to mow a yard and it wouldn't run full speed. I went to turn it off and then start it again and it was hard to start and when it did it blew a lot of black smoke out of the exhaust. Which I believe is too much gas. I thought it might be a stuck float so I took the bowl off and blew everything I could get to out. Put it back together same thing. But the weird part is when I moved it back into the garage I took the vacuum line off and it ran great. Does this sound like a clogged carb or something more with the vacuum line?
