carb linkage
jimwaltman
missing linkage 13AM775S058 2014 manu date 42" cut riding mower. throttle lever is not connected to carb. the guvenor lever is connected to the carb but not the throttle. what am i missing. anyone have a diagram of those linkages?
The throttle lever does not connect directly to the carburetor only the governor lever. The throttle lever connects to the governor lever via a spring at the control assembly.
jimwaltman
Thanks..... do you know where is could see a picture of the lever on the internet?
SeniorCitizen
This link may help some . + A spot of paint on each connection point before removal of cable ends and connection point makes identifying where it goes back even if it's years later . Color match each individually . The ladies keep many colors around for our convenience .
SeniorCitizen
A spring will be close by that throttle cable connection . The spring tells the the speed you want it and the Gov makes certain it runs there .
