CARB. LINKAGE 19-5 B&S
workinmac
:thumbdown: I HAVE A 19-5 HP B&S THAT USED TO RUN GREAT 'IF I COULD KEEP ENOUGH OIL IN ENGINE /HAD A TERRIBLE OIL LEAK / SO I TOOK EVERYHING APART A LOT OF THINGS THAT PROBABLY DIDN"T NEED TO. CLEANED EVERYTHING USED NEW GASKETS REASSEMBLED MOTOR /STARTS RIGHT UP BUT----- IT HAS A FAST ALMOST WIDE OPEN THROTTLE/ WISHED I HAD PAID MORE ATTENTION HOW LINKAGE WAS CONNECTED/ THANKS FOR YOUR HELP
Post your engine model numbers and I'll try to post a manual to help you adjust the governor linkages.
