Carb identification
Jonnyques
Hi can anyone identify this carb? Looking for a part# so I can buy a new one.
MTD Mower
11b021c516
Even if you know what the engine brand might be. I can't find any labels on it.
MTD does not give us the Tecumseh engine model number we need to give you a carb number. There should be a Tecumseh tag on the side of the shroud which will give us the model number of the engine. That being said, at this time of the year I rebuild about one of those carbs a day. Cost in parts is normally less than $25.00 and can easily be done by you. The part number you should get is Tecumseh #631021B and here is the procedure I use. If you still want to order a new carb, post the Tecumseh numbers and we will find one for you.
Needle and seat replacement.
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. Next check to make sure that the float does not have any liquid in it. If it does, replace. If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: On the side of some Tecumseh carbs you will find a plastic cover. Under this cover will be an idle jet. Remove it and check to see that the jet is open both horizontally and vertically. You should be able to push the old float needle wire through the vertical opening.
Hammermechanicman
If you want a new carb and are willing to use aftermarket take the carb off so you can get a good look at it. Go to ebay and sesrch MTD Tecumseh carb. Most sellers have enough pics you can match up to what you have. At around $13 new carb is cheaper than i can get a rebuild kit and spend time rebuilding one. I have used a bunch of them. Or you can rebuild the one you have or get an OEM for around $60.
