I have a 1996 Silver seried Lawn Boy. model 10227. Has good compression, new plug, good A/F,, thoroughly cleaned carb, new float and needle valve, I even sanded the rust off of the coil. New seals and reed. This thing will start on the first pull, will run right up to high idle, but it sounds like it's only hitting on every other stroke. It is a compleetely even miss, not random like some other 2 cycles. It will smooth out under a rather heavy load. I don't want to give up on it...what do you think? I don't know what else to do. The only thing I can come up with is to mess around with the float level, but that's a lot of work for troubleguessing...
BTW... new here, nice to meet you.
