can new PTO with 25lbs xtra torque break deck belt
jmzjojo
New here. Deere 2012 x300 178 hrs. 38" deck deck belts started breaking 2 seasons ago; past months have gone through 5 belts; They are Amazon OEM kevlar banded belts. They SNAP. 2 belts back I replaced the PTO with: HiTorque 130ftlb BIGBearing Blade Clutch & 10A PTO Switch OEM Upgrade fits John Deere AM147972 AM141536. This is a replacement for my part number, but it has 25lbs more torque. Could that be causing the belts to snap?? I had the issue before switching the PTO, so I still think there is something else and it is not the extra torque.
I also replaced one idler pulley even though I brought the deck to the Deere mechanic who inspected the deck and said all pulleys were good. The belts always snap; they do not fray....which is what I'd expect to happed if they were hitting one of the J-bolt hangers. I've researched this and read hundreds of comments on youtube. I've added washers under a pully, I've moved the J-bolt so it is not near the belt. I've leveled the deck . I have since put everything back as it had been (removed pulley washer and J-bolt back where it was). After 3 mowings, my last belt snapped. Comments from youtubers show some of these changes to work, but not always. Even changing PTO has not worked for some. I've levelled the deck again, I've used different brand belts. Guys using JD belts at a cost of about $70 still have them snap. I have just ordered a 5/8" x 144 kevlar belt from The v-belt guys website. It is 1/2" longer than the designated 1/2" wide v belt. I will examine all the deck again before I install the new belt. I only engage the PTO with the pedal lifting the deck to its highest position, then let it down slowly on cut grass. When the belt snaps, it is when the PTO button is pulled. After 3 cuttings on the last belt (once on very tall grass), I thought all was good.... then, pop! Anyway.... do you think the added PTO torque could be a problem? or any other things to check?
You probably got a bearing problem that has been overlooked. Bearings can develop a single spot that hangs and snap belts after they been sitting for a while. They have to be perfectly smooth when operating them.
It would help to see the newest belt that was damaged, but I suspect a belt guard is spaced to far from a pulley. These belts typically flop and vibrate, it a guard is too far away a belt can easily slip through and get pinched, then the pulley will cut the belt like a knife. The guards need to be close but not touch the pulleys.
Thanks for the answers. I took Startech's advice and meticulously looked for bearing slop. With no belt on, I found one blade spindle showing the tiniest amount of play.... the John Deere mechanic said it was fine. But, I removed all 4 spindle bearings and found one bottom bearing not as smooth turning as the others. I replaced all 4 bearing (2 spindles). I do not know if that fixed the issue, but I have a strong feeling that was the culprit. I don't know because, I mowed my lawn without issue, then sold the mower on Facebook, telling the buyer my entire history. But Startech telling me to look for what the mechanic did not see, got me there. Thank-you.
