I have a rz46i zero turn, that in the middle of cutting just stopped moving. Every thing else works normally as far as I can tell. The arms move, but it doesn’t go anywhere. Any ideas why and how to fix? Thanks.
My guess would be that the belt that drives the transmission derailed or broke. If you need to push/pull/tow it, be sure to find the hydro release levers to prevent damage.
