Bypass transmission rod
xoomer
I have a new Cub Cadet XT1 LT46 which I have used a few times. Last time I accidentally hit the gas pedal and bumped into a rather large plant, and the mower got stuck between the plant and a fence, so I, with a friend, pulled it out. Since that time my bypass transmission rod doesn't work properly--whether it is in all the way or out all the way, the mower will roll without a problem. Also, the mower still runs and cuts grass okay.
Is there something I can do to fix this? Or, in the meantime, is it alright to continue mowing without this rod working properly?
TIA
Please provide the product label information located under the operator set (usually). This will give us a better idea of how your machine is assembled.
