I have a fairly small 1/6 acre lot and I am looking for a new push mower and can't spend more than $200. I don't really need self-propelled and it just adds extra weight and more complexity (more stuff to break) anyway. Currently have an old 8 year old Murray with a B&S quattro (they are now called 500 series). Seeing some rust under the deck and I'm tired of having to replace the carb diaphragm and also since I usually mulch, it gets bogged down easily when the grass gets thick. I've scoured the area for a few weeks for a used mower, but there just isn't much out there in my area that is better than what I have.
I've been looking at mowers and it seems my best choices for new for under $200 would be the Husqvarna 6021p Or several MTD variants such as this Troy Bilt or this Craftsman.
The husqvarna uses a Kohler XT-6 which is an OHV engine so it should still provide plenty of power and should be a little more efficient and quieter and also uses the cast iron cyliner liners, forged crankshaft, and bearings for the flywheel for durability unlike the B&S flatheads, the other china clones, and even the honda gcv series. The mower also has ball bearing wheels, but they are still plastic, and seems to have an all steel deck. The MTD mowers have plastic at the front and rear of the deck where the wheels mount and use B&S 675 series (the old Quantum). That is an old flat head engine and it should be easier to get fixed should it break, but tends to be louder and uses more gas.
Power on both should be in the same ballpark and an improvement over the B&S 500 and 550 series mowers like I have now. So is there anything on deck design or other design features that I should be looking at? The husqvarna is recommended by consumer reports and scored decently on mulching. Is there a model I am missing? It seems like just about everything in the under $200 range is built by MTD (yardman, yardmachines, Troy-bilt, craftsman, huskee, bolens) or Husqvarna (weedeater, poulan). Please don't suggest the cheaper mowers with the B&S 300, 450, 500, 550 series motors as that is what I want to move on from.
As I mentioned in some other posts, I have been leaning towards the Husqvarna, but thought I would seek some more input to see if anyone else has an opinion
