BUILDING A FRONT MOUNT DROP SPREADER
I think I will look into the costs of liquid, definitely sounds like a lot less work.
Good news I have four to five months to come up with something.
Thanks for your thoughts.
Another trick with liquid is . You can add a green marking die so you can see where you have applied chemical/fertilizer. In a couple days of dew or one watering of the yard the die is gone.Everything I spray for customers is done with die in the tank mix.So when they return home and see my invoice including a liquid treatment they can visually see it was in fact done. :)
