Brush master chipperchipper with with DEK Engine trouble
Painting by Chris
  • / Brush master chipperchipper with with DEK Engine trouble
Hi sir or madam, I have a I have a D E K engine on my brushmaster chipper with less than 50 hours had a hard time starting the last few times I have used it.
At one point had kickback so bad which really hurt my hand when the recoil snatched back but I did get it started and did seem to be running fine and then died and could not restart it.
because the compression was too high I took the valve cover off and the rocker was laying in the bottom with a broken valve guide bolt wondering why this would have happened..
