broken shroud on underside of deck
Cedare_2
I have a 242 XD mower. The shroud on the underside of the deck, that goes around the mandrels, broke 3 of it's welds and is bent and hanging. Is this shroud necessary? Would it have much effect on the mower's performance if I removed it? Thanks in advance.
sgkent
only if you want it to work like the Engineers designed it.
Tiger Small Engine
Broken baffle that helps maintain the proper vacuum to cut the grass correctly. I have fixed 2 or 3 already this year. It catches on something when mowing and rips off the deck.
