I have Husqvarna yth22v46 with a Briggs 22hp model
445777-0231
-E1 and I was replacing the starter drive gear and the only way to get it back on was to remove a block and screw on the flywheel but the screw wouldnt come out so I drilled the head off to back the bolt out but the magnetized block busted, no I need both but cant find any info on just them other than buying the whole flywheel
Briggs And Stratton 84004658 - Flywheel, has anyone have any info on part numbers or what it is even called
