Broadmoor Transmission Merci no Reversi
wekjo
2015 Broadmoor forward pedal normal feel and action, however reverse pedal very difficult to push and almost no reverse motion. less than 400 hours on it. Seems to me that the little shock absorber at the end of the transmission actuator rod may be binding up. I pulled the boot off it and sprayed fluid film on it, looks pristine; however I have an older Conquest sitting next to it and the little shock absorber on Conquest makes no noise, but the one on the Broadmoor wheezes. I can't see any other bind points on the transmission linkage, nor any lube points. This problem came up suddenly, I see no leaking fluid on garage floor, nor on tranny, nor on axle seals, and dipping my finger in the tranny fill hole reveals fluid at normal level. Next step is to disconnect the shock absorber and see if range of motion is restored. Any other ideas?
Auto Doc's
Hello,
We need the model number and serial information off of the manufacturers label. Otherwise, we are just guessing what you actually have that you need help with.
Just on a wild guess, there is some dirt and debris binding up the linkage operations.
wekjo
2691279
2017061777
Already have up on blocks visual inspection nothing binding nor cluttering anything
