Has anyone had the issue where the engine wouldn't turn off thinking it was the valves and you set them and it still doesn't turn over then you think it the cam and when u see the ipls and there is not a acr on the cam. I haven't had this issue as of yet but a friend has. He set the valves,new battery,checked ground,new starter,new starter solenoid. I haven't had this issue yet so I can't really help him out. He says it will start and run good only if you back it off the compression stroke first then it will turn over good and start and run 44k777-0120-e1. If you have had this issue what was the fix? Thanks
