aka rotten
- Mar 21, 2012
- 44
Got a question for you experts.Briggs engine,Mod-2238-E1,Mod.42A707,Code0103195A,Enginehard to start at times ,Things done,New fuel lines ,filter,plugs.Once started ,runs fine,will run all day.If i shut it off,it,ll crank and crank then suddenly start and run fine.spark good while cranking,checked it several times.Only thing i havent done to it is replace fuel pump diaframs,ever.Sound like that could be problem?And could someone tell me what year that engine is by #,s.Thanks,Paul
