i have a woods ZTR mower powered by a briggs v-twin Vanguard 14hp motor. it started running rough then stalled. It will start perfect and run for 1-3 seconds then sputter and stall. Then if you restart it will do it over and over again. I replaced the 3 hose fuel pump, fuel filter and all 1/4 fuel lines. It is still doing it!! what could it be? PLUS now after the new pump it will barely run in low throttle. if you take carb cleaner ans spray a small amount in tjhe carb it will keep running this leads me to think its fuel delivery not electrical. The fuel pump it a 3 nipple square style mikuni made in Japan. Gas cap off makes no difference. PLEASE HELP!!
