briggs&stratton
brisco
I have a 5.5 hp BS will only run when i prime with bubble,cleaned out the carb( cabr is on gas tank) but still won't run by itself.Any ideas?
Check to make sure your gas cap is venting properly. If that doesn't do the trick, you've still got a little something stuck in your carb or fuel supply.
thanks, will re-clean carb and see what happens.
