greynold99
- Apr 24, 2012
- 16
- 87
Briggs&Stratton 500 Series/158cc/5.00 ft lbs Torque Hit stump, won't start; Fixable?
Hi everyone,
I hit a stump with my mower, blade is bent on one side and I couldn't pull the starter rope afterwards. It felt like the pulley was binding on something and wouldn't turn, though I was able to pull it a short distance after working with the rope a while.
It has a Briggs & Stratton 500 Series engine/158 cc/5.00 ft. lbs Torque
Model # 10T502-1022-B2
I was hoping someone would know if these engines are repairable or just trash after hitting something. On an older Murray mower I have with a B&S 3.75 Engine, the driveshaft no longer had a shear-pin on the blade/shaft mount spindle. But, I haven't even had a chance to look at the Weedeater mower yet to pull the blade or check the shaft at the flywheel.
I remember on the older lawnmowers, there would be a shear pin with the blade and one mounted with the flywheel that you could replace (That's how long it's been since I had to replace one...)
Thanks for any insight/help you can provide.
greynold99
Hi everyone,
greynold99
