knightowl71
- Jul 8, 2013
- 1
- 4
I recently acquired a used push mower that did run but not well. I broke down the mower to clean and tune up as it has been sitting for awhile. I replaced the diaphragm and gasket as I already had it apart. After putting everything back together, gas is leaking from between the carb and gas tank; it looks like it is coming from between the gasket and diaphragm. I thought maybe either the new gasket or diaphragm were damaged so I bought another from a small engine repair, a direct B&S part. After putting this new set of diaphragm and gasket on, it still leaks from the same spot. It did not leak here before taking it apart.
Is it possible that I warped the carb while rebuilding or that both new sets of gaskets were damaged? Is there any kind of sealant that I can add in this spot to stop the leaking?
Thank you.
Thank you.
