Briggs&Stratton 158cc
jak52
Have a Briggs & Stratton lawn mower brought new at Wallmart. Ran a few hours, then lost all compression.
Get us the model number info for the engine, also how long have you owned the mower.
shiftsuper175607
Did it come with oil in the mower?
Did you check it...or put some in? How much?
jak52
Filled with the break in oil. The piston/crank assembly works fine. Maybe a valve spring broke, or something happened with the cam.
jak52
961140004 09 Have had it for a few years, obviously should have returned it.
Two likely causes of complete compression lose is the rod is broken, or one of the valve seats has came out and is holding a valve open. May want to remove the head and take a look.
jak52
The exhaust valve is stuck open, and it isn't being held by the valve seat.
