The squealing starts after the engine is running. If started on concrete do not really hear squeal. Start to cut grass and will hear a periodic squeal coming for pulley starter housing after my research this is what I have done so far:
1) Removed the blower housing
2) Removed the black round friction cover
3) Removed the 2 pawls
4) Removed the little springs that were on a spike where prawl sat
5) Noticed 1 of the 2 spikes was broke where prawls set do not think would have much effect both prawls come out when cord pulled and retract back on recoil
6) Removed pulley and cleaned
7) Removed spring and wiped down with acetone
8) Reassembled spring and lubricate with automatic transmission fluid
9) Reassembled and lubricated with ATF the little prawl springs and placed friction disk
10) Wound the pulley counterclockwise until is stopped then backed off 1 full revolution and lined up holes for cord.
11) Adjust cord length so no slack and good resistant for east start 1 pull.
12) Started mower let run few minutes on concrete no squeal
13) Started to cut grass was ok for 30 seconds then fait squeal not as bad as before.
14) This engine is different then many YT videos my flywheel has a cup on top the is 15/16th bolted to flywheel and crankshaft.
15) This squealing is driving me crazy trying to figure it out.
16) Some YT folks say a starter clutch not sure mine engine has that? B&S parts diagrams do not show that.
Thoughts????
Thoughts????
