Hi All -
I have an old Briggs and Stratton engine on my Toro Wheel Horse 210-5 (circa early 1990s). Trying to keep it alive. The mower wouldn't start, so I checked compression. I had a 0 psi reading, so I pulled the engine and rebuilt it (including new valves, piston head, and rings). [It turned out to be an intake valve return spring coming loose, but I rebuilt the whole thing anyway.] The cylinder bore looked good and I did not see any scoring. Tried compression on it after the rebuild and got 90 psi (which was good). Started it up (there was some smoke) and tried to fine tune the carb. Went back to work on it today and it would not start. I got a 60 psi reading on compression today. Unsure why compression would drop? Anyone have a good place to start looking before I tear the whole thing apart? I am thinking maybe the valves again.
Any help is greatly appreciated.
