I just did a head gasket replacement along with bottom oil seal on a briggs 20hp intek twin. after cleaning head and motor surface super clean i reinstalled the heads with new gaskets, cleaned head bolts and torqued to factory specs and after 15-20 minutes of mowing the right side facing mower started leaking, oil filter side.
What would cause this ?
