Captn Cliffy
- Dec 3, 2010
- 8
- 29
I have a co-worker who ran his lawn tractor with low oil, and the connecting rod broke. B & S model-type 31C777-0226-E1; code 040319ZD. There is a fair amount of scoring on the crankshaft journal for the rod. The piston and cylinder bore don't appear to be damaged. My question is, how long do you think the engine would last if he just cleaned up the crank journal a little with emery paper and slapped a new rod on? I'm thinking since the rod is aluminum, any scoring on the crank journal would wear out the rod soon. There is no undersized rod available, so you can't turn down the crank. The only other option I see is replace both the crank and rod. Thanks for any thoughts!
