HELP : M-305447
T-0568-f1
I installed a new carburetor & adjusted the valve clearance on both intake & exhaust ( turn the flywheel to the end of the compression stroke & gapped both valves to 4-5 THEN turned the flywheel again to top dead center to adjust the other side as well ). When pulling the starter rope i get a backfire & the rope at times is hard to pull. I went to the conclusion that the flywheel key may be damaged. I pulled flywheel and everything is intact. Spark plugs are new.
Any Suggestions ?
T-0568-f1
Any Suggestions ?
